06-30-2026 01:11 PM
Hello
I recently switched to Public and since then haven’t been able to reply to android text messages I have received. When I go into my settings it says RCS-waiting for activation
please help with step by step on how to fix this.
thanks
06-30-2026 01:16 PM
yes,it is an RCS re-registration problem on Google side
what you need to do is to make sure you removed the old carrier sim card and disable the old esim. Then uninstall Google Message (or choose Uninstall update), then wait 15 mins, reboot your phone and reinstall Google Message and enable RCS to trigger a re-registration
