03-16-2023 09:37 AM
Hi there,
I purchased the US Roaming bundle ($33.90) before leaving for the US. It expired on Saturday (March 11), while still in the US. On Sunday (March 12), I tried to purchase the same US roaming bundle, but for some reason it wasn't working. Not sure if it matters, but it said I had -1/15 days left on the plan, in stead of 0/15?? I was given a pdf receipt of my purchase, but the purchase didn't show up in my account. I tried it a few more times, each time getting a receipt but the purchase didn't show up in my account or on my Mastercard bill. I tried this process again on Monday (March 13), and finally gave up and just just tried to purchase the data roaming ($25) and talk/text ($15) add-on separately, and it finally worked (although it costed me $40 instead of $30). Another weird thing I noticed, is that these separate bundles don't seem to be showing up as Add-on options anymore in my account. So here is where I need help - the billing side of things:
Thanks so much!
03-19-2023 09:00 PM
If you show the amount in your balance then just leave it there for your next add-on or renewal.
Re-buying the same add-on needs to wait. You can always ask support to re-buy it for you at any time. You could also buy the different bundle when the first one goes to 0/15. But not the same one if you see it available for purchase.
03-19-2023 08:58 PM
I was able to buy the add on, but my mastercard was charged twice, so I'll open a ticket as recommended. I am also still confused because the amount of money that I've loaded into the account, and the amount taken from my mastercard don't seem to line up. Also - what does it mean to check My Account's payment history using incognito mode (I don't know what incognito mode is, or why I would need to use it).
Also, if I understand correctly, I need to wait 24 hours AFTER my roaming plan expires, until I order it again. What is the best way to get continuous US roaming for more than 15 days (without having a 24 hour period without service)? Thanks.
Thanks.
03-16-2023 11:30 AM
@cjan wrote:Hi there,
Thanks for your response. Both charges are showing up on my mastercard bill, BUT both are still "pending". Are you recommending that I wait until they aren't pending anymore to confirm if I will actually get charged twice?
@cjan were you able to re-buy the addon now?
and check My Account's payment history (using Incognito mode) and see what PM shows there
https://selfserve.publicmobile.ca/en/account/payment/payment-history
03-16-2023 11:07 AM
Re-buying the same add-on is ridiculously tricky. For now, login to your account using incognito or private mode and see what you have for a balance. And see what you have for add-ons.
Roaming add-ons showing 1/15 are still valid and should still work. Showing 0/15 says they've expired and should not work.
If the add-on says 1/15 (or more) then the add-on should not show as purchasable. But I'm not 100% certain of this suggesting this is a glitch. Because buying the add-on at that time does not work as you found.
Your new other add-ons also should not show as purchasable as you found.
If you're not strapped for cash, just leave the money in your balance and your next renewal will use it first before autopay.
In future, you could do your method of buying the different add-on - when it says 0/15! - or you would need to either wait it all out or ask support to re-buy it for you at any time you like.
03-16-2023 09:58 AM
Hi there,
03-16-2023 09:43 AM
@cjan for US roaming add-on, after the first set expired, you are supposed to wait 24 hours (some said 12 hours) before you can re-buy the exact same one again. If you didn't wait, PM usually would have taken the money, loaded in the account but didn't make the purchase. However, usually the money is sitting in the account and when you buy again later (after the 24 hours), PM should not charge you again
In your case, your sure both March 12 and 13 charges are real charge and one of the two not pending charge? Check with them first
If they are real charge, also check your My Account's payment history and see if it shows PM charged you on the both days
If you need PM support to help refund or investigate, please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
