Charged for a plan I didn’t get
LiamB4
I payed for the new student plan but I only received the 10.5 gb at 3G speed, but I was charged for the student plan.
How do you know you didn't get the new plan @LiamB4 ? Call 611 and check your data balance, it is tell you higher than your old plan?
Alexandf
@LiamB4
Try different browser. Try incognito mode. Clear browser cache,cookie, Try refresh.
not see it,, PM support send private message CS_Agent at: ask them to fix it
(envelope icon on the top right) CS_Agent will reply you there.
dust2dust
Click on the little spinner refresh icons lower down. That might show the new plan. Or try incognito mode.
