Changing to 5G phone
JEN58
My current plan is for a 3G phone. I want to buy a 5G phone and switch to a 5G plan. Can I use the same sim card  or will I need a new one?
9 REPLIES 9
@JEN58
What 5G phone were thinking of getting?
Check to see if it is 5G compatible.
JEN58
excellent - thank you
@JEN58 wrote:
It's a Samsung 7 Edge
HI @JEN58
yup, Samsung S7 Edge is a bit old now, it can do neither 5G nor VoLTE.
But it has nano sim, so, you can use the same sim card on your new phone for sure
JEN58
JEN58
Thank you!
@JEN58
The SIM will be interchangeable between all phones but you might have to remove or add a spacer depending on what phone you are switching to. Most newer are nano size SIM.
Older phones use standard or micro size where you need to carefully remove the spacer without scratching the copper connectors.
HALIMACS
@JEN58
can you share with us the make and model of your existing device?
Are you certain it’s incapable of anything other than 3G?
hi @JEN58
yes, the same sim card can be used for different plans and different phones
so, just pop your sim card out and insert into the new phone, and make plan chnage (best to use Change on Renewal when making plan change)
Chalupa_Batman
Nope. Your current SIM card will work just fine. You can use the same sim card or you can get an eSIM if you prefer. That way, if you get an iPhone 13 or 14 you can use dual SIM and have two numbers on your phone.
