Transferring Number While In USA?
TucDream
I have new Public Mobile plan (with a physical aim and a long standing TELUS service (for the same phone).
I watched the PM YouTube video about the transfer/port process, but it wasn't clear if it will work when I am in the USA.
If I put the TELUS sim in my phone while in the USA and start the transfer/port process while in the USA, will the process work properly, or do I have to do it when back in Canada?
Thanks in advance.
@computergeek541  Thanks got confused for a min @TucDream  yes leave Telus sim in  phone to reply YES to the confirmation text sorry
@Handy1 wrote:
@TucDream  Yes it should work , and especially if the public mobile plan you have is CAN/US roaming plan or you have US roaming add on  . Then just leave the public mobile sim in the phone  reply YES to the confirmation text to port . And just use the Telus account number and ignore the IMEI it’s not needed
This customer isn't porting to Telus Mobility, so the plan that the customer chose for Public Mobile makes no difference.  The porting authorization will come from Telus Mobility.  In any event, Public Mobile and Telus Mobility customers do not need roaming add-ons (or a plan that specifically includes U.S. roaming) to receive text messages in the U.S.
