12-03-2024 03:06 PM
It has been hours since my previous service provider confirmed my number was approved to be transferred. How will I know that it successfully has been? If it ends up taking longer than 5 hours, who can I get in contact with?
3 weeks ago
I called the support team and got it all worked out, thanks so much for the help!
12-03-2024 03:14 PM
hi @Ameliacampbell did you reboot your phone with the PM sim inside and test inbound calls?
if you cannot receive inbound, likely port is not done
But check with PM porting support team and confirm. I have sent you the number to PM Porting support team Please check your community inbox: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
