Changing phone a number
08-23-2024 12:03 PM
How can I change the phone number that I've got service for . for example me and my daughter are both customer of public mobile. But my account has more points because I am older in public mobile if I don't wish to be with public mobile Anymore . Can I give my account to my daughter instead of the cancel of my account. That means I want to be all the service and my point for my daughter number. How can I do it?
My Account
Service
08-23-2024 12:49 PM
HI @Maryamj
The Transfer Phone number option is to transfer number from another carrier into PM, not within PM
You can of course try and it will show an error
or if you want to get a formal answer from PM agent, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
08-23-2024 12:47 PM
But there is a option in the account under the profile called transfer number what does that for?
08-23-2024 12:42 PM
HI @Maryamj
as explained above, you cannot swap numbers between account
If you like the number so much, just take the sim card from your daughter and use it on your phone. You can also login to that account and change the name
(of course, in the end, the rewards on each account would stay where they are)
08-23-2024 12:40 PM
The question is, I would like to take my daughters number. she wants Change her number and her number is really good so I would like to take her number and transfer it into my account instead of my number. I don't want to use my number anymore? Can I do that?
08-23-2024 12:32 PM
08-23-2024 12:18 PM
HI @Maryamj
sorry, points and funds are not transferrable. You cannot transfer your fund to your daughter.
You cannot swap numbers between 2 accounts too
