10-29-2021 08:35 PM - edited 01-04-2022 05:19 AM
Changed Number was never detectd by the phone, which still shows the old number.
Can't rechange the number in Self-Serve.
Phone won't load new number.
Public Mobile has no real Customer Service, so they might lose a Customer.
10-30-2021 12:01 AM - edited 10-30-2021 12:03 AM
10-29-2021 11:49 PM
moved/removed posts from this thread (terms of service)
10-29-2021 11:39 PM - edited 10-29-2021 11:42 PM
@Statilius wrote:Why am I getting worthless messages from **** here rather than a Customer Service Support rep just reset the SIM Data Sync..
@Statilius Respect others and respect yourself..
We are all here trying to help you. You can be upset with PM but what you are saying is totally unacceptable here.
There is no place for offensive word like that in this Community. I have reported your post for inappropriate contents !!
10-29-2021 11:14 PM - edited 10-29-2021 11:15 PM
FWIW, I changed my phone number a bit over a year ago, my new number was reflected on my old SIM card somehow. I had a (non-rooted) Samsung Note 9 at the time, and don't remember having to do anything to reprogram the SIM.
10-29-2021 10:22 PM
@hTideGnow wrote:@will13am what other workaround if there is no root access?
does putting it on another phone help?
No other work around that I am aware of. I have always had access to a rooted phone. I have shoebox full of them. Putting the SIM into another phone does not do anything. One thing I have not tried is doing a SIM change after a phone number change to see if that does anything. I am not that technically knowledgeable with the number change process. Long ago, I google searched and found a root app that does the job.
10-29-2021 10:01 PM
@Statilius wrote:
But if you want to keep your customer, you're gonna fix your SIM-Network Sync issues ASAP
We are all just customers like you. We might be able to suggest you what you can do on your end with your device. Posting here won't make them fix your issue. Like it or not, you need to follow their support model if you want your issue to get resolved. Open a ticket with PM now.
10-29-2021 09:35 PM
10-29-2021 09:31 PM
@Statilius , is your problem only just the phone not displaying the revised phone number? Based on my personal experience this seems to happen with all carriers brands when a phone number is changed. The new number does not get programmed into the SIM card, but the new number does work with phone calls and text. My workaround is to force program the number into the SIM card using a phone number changer app that works on a phone with root access.
10-29-2021 09:28 PM
@Statilius wrote:Not interested in Community Help,
Welcome to the Community , you came here and ask for help yourself 🙂
if you want traditional customer support, check Koodo or Telus. You can even port your number over. But.. you need to make sure your phone is receiving incoming text with your new number to authenticate the porting request 🙂
10-29-2021 09:28 PM - last edited on 10-30-2021 06:59 AM by Andu_S
I have multiple numbers on multiple platforms in multiple countries, I don't need your service.
But if you want to keep your customer, you're gonna fix your SIM-Network Sync issues ASAP, ******.
10-29-2021 09:25 PM - last edited on 10-30-2021 06:58 AM by Andu_S
Not interested in Community Help, I want salaried employees to take care of their problems. Corporations are fictions, Your judges are ******* anyways
10-29-2021 09:21 PM - last edited on 10-29-2021 10:34 PM by computergeek541
@Statilius wrote:
Curious, not legit because it is just being a different support model ?
I am just a customer like you (yes, we are not same :)) and I am just trying to offer you as much help as I can
PM is a mobile service provider than their employees do not work in waste management 🙂
edited by computergeek541: removed quote of inapprorpiate content posted by a different member (not the member who posted this message)
10-29-2021 09:10 PM - edited 10-29-2021 09:10 PM
Abusive language will not be tolerated in the community. We are just fellow customers volunteering our time to help other customers. Please refrain from further outbursts of this nature. We do understand it can be frustrating when your phone and or service is not working correctly.
Public mobile has an online only support business model. It is quite clear there is no customer service call centre. If you cannot deal with creating a customer support ticket thru Simple--Simon then send a private message to the CSA's. Otherwise you can work with us to try and troubleshoot your issue. Please be advised that CSA business hours finish at 10pm eastern.
10-29-2021 09:06 PM
@Statilius wrote:All done pre-contact here, none worked.
be cool and no other way to getting help only from them,
you need to Contact Customer Support Agent by CS_Agent,
you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
10-29-2021 09:00 PM
10-29-2021 08:58 PM - edited 10-29-2021 08:59 PM
@Statilius wrote:Has absolutely nothing to do with the browser, the phone won't connect to 3G nor LTE to refresh the new number. It's not a Browser Problem, the phone will not load the new SIM data.
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
10-29-2021 08:57 PM
10-29-2021 08:54 PM
10-29-2021 08:48 PM - edited 10-29-2021 08:50 PM
@Statilius wrote:Changed Number was never detectd by the phone, which still shows the old number.
You reboot the phone yet? Maybe even take the SIM out for a minute before putting it back in.
also, if you logon to My Account, does it show the new number there?
and no, you are not right.. PM does have real customer service. you just didn't engage them properly 🙂
here you are:
To open a ticket with Customer Support Agent, click on the Bubble or directly at : https://publicmobile.ca/chatbot
Enter your question in SIMon. Follow the prompts until you reach the Contact Us button,
If you have problems submitting a ticket, you can also send a private message to CS_Agents (but this can take longer):
10-29-2021 08:38 PM - edited 10-29-2021 08:42 PM
i suggest you close all Browser and do clear cache and cookies for any Browser,
and try open Browser incognito mode,
Changing Your Number
You can change your phone number up to 4 times every 30 days after you’ve activated. To change go to your Self Serve Account here link, and:
if still can't you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
