Changed my plan do my rewards get transferred to the new plan (friends referrals, autopay, loyal)?
zareiemilad
If I changed my plan, do my rewards get transferred to the new plan (friends referrals, autopay, loyalty)?
1 REPLY 1
Yes @zareiemilad   yes, you will get all the rewards the same on the new plan, so same amount of discount
and NO, you won't get moved to the new rewards system for changing plan, you will stay on old
