Change plan upon renewal date
becm66
I tried this option last month. Saved the changes and it never changed. Im trying again this month. How can i check to make sure it will actually happen?
pmbc
@becm66  Along with the suggestions below you could have CS Agent confirm they see the same thing as you see on your account.  Explain it didn't change last month and you just want to confirm they see the plan will change for the next period.
You can contact an agent using the chatbot.  Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
Yummy
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Confirm it really did not change.
If not, use computer and schedule again.
@becm66  Do this first
simply try refreshing the page when logged in
@becm66   you sure it didn't change?  maybe it is just a cache issue and you are not reading the updated info
Please login to My Account again using Incognito mode.  Confirm which plan showing as your current plan.
If still the old plan, you can schedule a plan change using Change plan on renewal date option
Then logoff. Wait 5 mins and log back on  using Incognito mode again.  Go to the Change plan page and you should see it showing you have a scheduled plan change.
Again, using Incognito mode to login is the key. Some browsers call it Private mode or InPrivate mode
