Change monthly plan
sartajkhan
Talk to agent
8 REPLIES 8
Timer
@sartajkhan
do it by yourself to change plan go use browser from computer,and clear cache and cookies and use one page inPrivate mode,or safari on private mode,To Login Page
and go to Plan & Add-ons, and scroll the plans using the down and up arrows on the far right. select the plan you want, and select ‘Change plan now’ then you pay full price plan, or ‘Change plan on renewal date’..to you not losing any money..
if still can't changed then contact PM support team by CS_Agent
DDM69
LOL 😂
Yummy
You do not agent to change plan.
After logging in to your account go to Plan & Add-Ons, Click on Change  My Plan, pick Plan and select Change plan on renewal date or Change plan now
@sartajkhan wrote:
No
Who are you trying to answer?  By any chance did you receive a private message from CS_Agent?
dust2dust
??? You can login to your account to change your plan. You don't need an agent.
@sartajkhan problem with changing plan?? you can do it without talking to agent.   Just login to My Account,  go to Plan and addon page and click Change my plan.  Use the yellow arrows on the far right , or at the bottom for mobile site,  to scroll through the plans and select the one you like
let us know if there is any problem
@sartajkhan wrote:
Talk to agent
You've posted on the message forum instead of in the chatbot.  Please make your request through:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
sartajkhan
No
