09-13-2026 01:18 PM
Hello I had changed my monthly subscription to lower data but at the last second canceled the planned subscription change, however now I dont have any data at all. Can I please get my old subscription back
09-13-2026 01:28 PM
using the mobile app, log in to your account > scroll up to find Usage Breakdown....you should see details of your current plan including how much data you have and used up.
09-13-2026 01:20 PM
did you check My Account to confirm account is still active? Please check again using Incognito/private/secret mode on your browser to login My Account
if it is active, try Reboot your phone and reset network settings
if same, then submit a ticket with PM support agent. You can submit a support ticket right at My Account and PM app using the Expert Messaging in one of these ways:
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
https://expert-messaging.publicmobile.ca
Remember: Support hours of operation: 9 AM to 10 PM ET
