What is happening!?
DanaJ
Hello!
I’ve recently changed my plan. Payment page shows the transaction but when I’m on the PM website thru a browser it says I’m on my old plan, and if I go through Google, it shows my new plan… anyone know if the site has a glitch or am I missing something?
Old plan via safariOld plan via safariNew plan via googleNew plan via google
Timer
@DanaJ
it is just a glitch in the system there is a new design some customer has same issue.
tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,orsafari on private mode, To Login Page
or call *611 press 3 and you need your 4 digit PIN and check it out data usage.
halofreak79
Should correct itself shortly. Can clear your cache if youre concerned
hairbag1
Below Account Status, look for the Update circle thing...give that a try ...it should update your account.
added pic...
Outdoorsman
@DanaJ hi you just need to clear your cache and cookise or use a different browser in incognito mode , reboot and you should see that it updated
Yummy
Most likely you are seeing cached page.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try force refresh.
Force-refreshing a page will clear that page's cache, allowing you to see the most recent version of the page as opposed to any information your browser saved in the past: CTRL+F5 or Ctrl+refresh icon (PC).
