07-26-2022 10:58 AM
Hi Everybody, I'm wondering if it is possible to change my active 3G plan to a 4G plan? It looks like the option was a possibility in the past?...if so, will it be possible again? Thanks in advance for any help!
07-26-2022 12:36 PM
@nmcneill wrote:I am having the same issue. I go to plans and add ons-not there. When I click on change my plan, only 3 g options show up. I have an active account with auto pay. HELP!
All Plans are there just keep clicking.
They are sorted by cost so they are little bit mixed up.
07-26-2022 11:29 AM
Thank you!! This worked perfectly!
07-26-2022 11:19 AM - edited 07-26-2022 11:20 AM
Thank you friends! The solution that worked for me was to keep clicking/tapping the arrow buttons until the 4G plans showed up as options. It looks to be a user interface improvement that could be made for the 4G plans to be more visible. Thanks again 😊
07-26-2022 11:16 AM - edited 10-20-2022 02:20 PM
Try to use an Incognito browser or use a completely different browser (Edge/Firefox/Chrome)
Also, when you are at the change plan site , make sure you see the yellow arrows on the far right, you can scroll the list up and down for different plans
07-26-2022 11:15 AM
@GIE hi I just checked and they are there use the down arrow to scroll down if for som reason it doesn't work, log out and use a diferent browser and log back in and use a differnt device not a phone 😀
07-26-2022 11:10 AM
07-26-2022 11:03 AM
Thanks @iliketotalk
When I click on Change Plan, it goes to a selection of plans, but they are all 3G plans. No 4G plans are presented as options 😑
07-26-2022 11:00 AM
@GIE yes just go to plans in your account use the scroll down arrow pick the plan you want
