yesterday
My husband and i have been having trouble with cellular data. I have an iphone and he has an andriod. Yesterday we both could not get on the internet or use any aps. And the same this is happening today. Turned off and on airplane mode as well as the cellular data. Works for a few minutes and then cuts out.
Any ideas????
Thanks
yesterday
For no apparent reason my data has stopped working. I haven't got anywhere near my limit and I've checked all my settings and nothing has changed. Any help would be appreciated!
yesterday
Are you in Ontario? Public Mobile is experiencing some service issues now and mobile data might not be stable until the issue is fully resolved. In the meantime, Reboot your phone every once in a while
yesterday
I have service and full bars but my data randomly goes away. It won’t say lte or anything. it works when i turn my phone fully off and back on but just wondering if there’s a quicker way so I don’t have to do that 10 times a day.
yesterday
I've lost data in Ontario today. Still have lots of data available, talk and text work fine.
yesterday
I had been using it without any problems, but since yesterday, my internet connection keeps disconnecting
When I turn my phone off and on again, it connects for a short time, but then it disconnects again. This keeps happening repeatedly.
What should I do?
yesterday
I am not getting internet in my mobile since yesterday. However I am able to make call only internet is not there. I recently opt to upgrade the plan which will be applicable from tomorrow. is that somthing impacting my mobile internet.
yesterday
It appear that there is an issue. For now, they airplane mode on and off.
yesterday
I had tried this , it had work temporarily; then down again.
yesterday
I can’t access my cell service- no phone calls and can’t use data. Is there an issue with the system? Living in NB
yesterday
many of this problem today. Reboot phone and reset network settings would make it works again
yesterday
@Flinstone wrote:My cellular data just stopped working. All settings on my phone are ok.
yesterday
yesterday
yesterday
hi @Cvark
are they in Ontario?
PM has been having some data issues for some subscribers, so, it likely you are just part of those affected.
Try Reboot phone and Reset network settings when needed
if you like, report that to PM support agent as well. Submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
yesterday
Starting 2 days ago noticed data drops on mine and my partner's seperate plans. They are active. Have tried resetting network powering off phones.toggling between airplane mode sometimes helps.
yesterday
I'm in Midland and am also having issues as of yesterday, rebooting my phone no longer works 😞
yesterday
Same happened here in Saint-Laurent (Montreal, QC) since yesterday. No data network connection, only voice on 3G network. Phone is usually connected to LTE+ or LTE networks. Just rebooted the phone as suggested and now it seems that LTE+ has come back on.
yesterday - last edited yesterday
I did reboot phone, and it would work for a second and then out again, I rest the network settings and then another reboot and still no data.
yesterday
No I am in Ontario
yesterday
I am also having data issues in Markham area. Tried restarting my phone but found no change. Data worked ok this morning.
yesterday
could be but what area are you currently in ?
yesterday
hi @duvey
possible there was some issues, mainly in Ontario and Manitoba
yesterday
hi @JFitness
are you in Ontario or Manitoba? seems like PM has some data issue in the past 2 days.
Try reboot phone and click Reset network settings and test again
yesterday
is data down
yesterday
yesterday
Hi all.
Thought I posted here, but dont see it.
I removed my SIM card (physical) while phone is on. Had to restart, and then worked for me.
If you have an eSIM could try turning off/disconnecting Public Moble one for 30 sec or so, (don't delete it) and then restart to see if that helps. eSIM worked for my wife.
yesterday
I'm in Alberta, I've not had Data for a while and all the settings settings suggested and the airplane mode and wifi assist turn off doesn't do squat. They need to get their act together and nake sure that the registered number is allowing Data on their network. I'm porting my number over to another provider. Tired of dealing with automated clowns and gremlins in their network. Fix the your Network!!!!!
yesterday
I have the same issue as posted. Doesn't work. Airplane Mode off, Wifi assist off. Get us help with this it's not the phone it's your crappy network that blocks Data access.
yesterday
No, in ontario
yesterday
Make sure you didnt turn on airplane mode
