9 hours ago
- last edited
6 hours ago
4 hours ago
@Robnickname , we are ALL customers like you here.
To confirm if your phone will work with Public Mobile, please see this link. At the bottom of the page, you can insert your IMEI number and the system will advise you if it will work with Public Mobile.
https://www.publicmobile.ca/en/get-help/articles/volte
Use Public Mobile's VoLTE checker as a guide only, as results are not always 100% accurate.
It may be a 4G phone, but it may not be a 4G approved phone, hence the reason for all the messages.
4 hours ago
Today I received a text message to let me know that I will have to replace my phone to keep my current monthly plan rate. The text says a 4G LTE/5G device is required but I don't see any 4G plans being offered. Will a 4G device work on a 5G network?
Do is PM actually requiring a 5G device?
4 hours ago
Hello
I've been receiving notices lately that my subscription fee will be increased by $5 per month on June 15, 2026.
My current phone is a 4G phone. Also, the service bars at the top of the screen when I'm connected to Public Mobile show "4G".
What is the disconnect here?
Can you check from your end and/or have me do anything from my end to confirm that I am a 4G (not 3G) customer and that my subscription WILL NOT INCREASE by $5 on June 15, 2026.
Rob S.
4 hours ago
It checks out on their website
5 hours ago
I would be proactive and submit a ticket here:
I think all impacted customers need PM to address this issue.
5 hours ago
hi @Markk123
what is not working? the phone or the message?
for message, you can submit ticket by direct message:
5 hours ago
Samsung Galaxy S21 FE 5G
I've tried opening a ticket through your links but they don't seem to be working
5 hours ago
We don't know, we are just customers.
So, it is best to confirm with PM.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
5 hours ago
hi @Markk123
what phone is that?
there are couple posts about that. It could have sent wrong, but I would check with PM support agent to confirm. And make sure to send them the screenshot
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
5 hours ago
The IMEI checker states my phone is compatible with volte
Why am I getting texts stating that my phone isn't compatible and there will be a $5 charge?
5 hours ago
@cigarsmoker wrote:do you have any timeline when PM will shut it down
PM is not shutting down 🙂
it is the 3G networking going to be decommissioned. All providers are doing that
with PM (telus and bell), it is March 2027
5 hours ago
@bronneyhui wrote:Is there a place for me to check which phones are whitelisted instead of buying a phone first and found out it's NOT SUPPORTED?
they had a list before but they no longer posting that
a safer bet is to buy only the Canadian model of the mojor brands
you have any model in mind? share and we can help
6 hours ago
@DW88 wrote:Is the Oneplus 15 compatible with PMs VoLTE? My current phone is also affected and I'm looking at options.
we don't know, eveyrthing has to based on the compatibility check. Please confirm if your phone is on the whitelist by using the VoLTE checker at the bottom of this page:
if it is not on it, then sorry, you need to pay the $5 for now until you get a new phone. And yes, you still need a new phone as PM will close down the 3G network in March 2027 and you would have no voice calls then
6 hours ago
Double check your phone below. What type of phone do you have? It might not be on PM whitelist and if so, the reason for the message and rhe heads up for you to change your phone soon.
6 hours ago
6 hours ago
it has to do with the phone, your phone might have VoLTE but it is not on PM's VoLTE whitelist. So, if it is like that, your data might be using 4G or LTE or 5G , but calls will go back to 3G
6 hours ago
Today I received a message from public mobile that there is going to be 5 dollars charge begining of the next month on my bill due to 3G network usage!
I don't use 3G network and my phone set up is on preferred 4G Lte network.
What's this about?
6 hours ago
7 hours ago
hi @NT31
this is device dependent and not plan
check if you current phone is on PM's VoLTE whitelist or not, if not, you need a new phone
7 hours ago
some VoLTE capable phone can still not on PM's VoLTE whitelist.
7 hours ago
@NT31 ,
Thisbis not about the plan that you are on, but your G7 is not supported by Public Mobile soon, so you will need to change your phone to one that will be supported after March 2027.
You can use the chatbot to submit a ticket.
7 hours ago
7 hours ago
I got a msg that if I continue to use my device which is Motorola E5 PLAY Power and on 3G, my subscription will increase by $5 to become $30 ... if l switch to 4GLTE/5G I can avoid this amount I am not sure if this is device dependent - do I need to change phone? What's going on if your saying l need to change phones are you going to buy all your customers new ones
7 hours ago
I received a message saying my device is using the 3G network and may be subject to a $5 surcharge.
However, my OnePlus 8 supports LTE and VoLTE. During calls, the phone shows HD Voice and remains connected to 4G/LTE.
I believe my device may have been incorrectly flagged as using the 3G network. Could you please verify whether my account will be subject to the surcharge?
7 hours ago
Hello wonderful people, I got a msg that if I continue to use my device which is Motorola G7 Power and on 3G, my subscription will increase by $5 to become $30 ... I am not sure if this is device dependent - do I need to change phone? I checked online rates for G4 & G5 they are less than $30 - I hardly use the texting capabilities... any insights or how to get the attention of customer support. Thank so much for your help and have a wonderful day.
7 hours ago
I don't belive that your phone is on public mobile whitelist . It will revert back to 3g for calls, which is why you are receiving that message
But I would verify with Public Mobile directly.
7 hours ago
7 hours ago
4G LTE support and VoLTE are separate things. Further, each device needs to be white listed by Public for VoLTE support, so there are some devices that have VoLTE support but yet don't work with Public. It's possible Public may add some more devices to the list, but I wouldn't count on much, if any change in the list. If the device isn't showing up with VoLTE support in the device checker on the help page it's notice that the device is not going to work when 3G gets shutdown, https://publicmobile.ca/en/get-help/articles/volte
The $5 fee will only be temporary as a 'stick' to push people to move off incompatible devices, before the 3G shutdown happens and they lose the ability to make calls at all.
7 hours ago
Why don't they just say they want $5 a month more, instead of being murky about why this would apply? Pubic Hair Mobile has the worst customer service. So much so, that they leave it to their customers to resolve problems for each other. What a stupid **bleep**ing system!
7 hours ago
If the Public checker says your device supports VoLTE and yet you got the message, I would consult with customer support to get to the bottom of this so you don't get surprised when 3G gets shut down.
