3 weeks ago
- last edited
3 weeks ago
3 weeks ago
Definitely they got a list of whose naughty and nice....does it make sense if your phone HAS the capability....no, its likley one of those favoring someone or something because no one is watching too hard...
3 weeks ago
the complaint process won't help, you won't get anything out of it
Mobile providers are allowed to setup their network requirement. There is no rule to force mobile provider to accept all phones and any phone to their network.
And your phone might have VoLTE but it is not on PM's VoLTE whitelist. So, if it is like that, your data might be using 4G or LTE or 5G , but calls will go back to 3G
confirm if your phone is on the whitelist by using the VoLTE checker at the bottom of this page:
https://www.publicmobile.ca/en/get-help/articles/volte
if it is not on it, then sorry, you need to pay the $5 for now until you get a new phone. And yes, you still need a new phone as PM will close down the 3G network in March 2027 and you would have no voice calls then
3 weeks ago
Make a call a check the status of the phone while in the call.
What does it say?
3 weeks ago
hi @Tony67
You might have a 4G or even 5G plan and using 4G/LTE/5G for data, and your phone might support VoLTE, But PM has a VoLTE whitelist and only phones on the list can use VoLTE.
Since you got that text, your phone likely is not on the VoLTE whitelist. If that is the case, while you are using 4G or LTE or 5G for data, when you are making calls, the system will ball back to 3G for voice calls.
When the 3G network ends, you won't be able to use any network for calls with your current phone
So, what phone do you have? and which province?
check if your phone can use VoLTE using the IMEI checker here:
3 weeks ago
Does anyone here have an actual LTE capable phone, but if being told that its 3G because it is being denied to ebe registered on their towers as an LTE. Then they send you a msg that you will be charged $5 more because they are phasing out 3G. Well, i am preparing to go "upstairs" with this wiht a CCTS complaint process.
3 weeks ago
Maybe for others. But Koodo and Telus accepts my wife's S10 phone -- but PM does not. Makes me think PM is trying to drive customers back to parent Telus (or Koodo), or buy one of their over-priced new phones
3 weeks ago
3 weeks ago
$5 bucks a month = $60\year + taxes. Yes, a compelling argument for leaving, providing there's a good alternative to PM's offerings
3 weeks ago
S25 will certainly work, no doubt
but make sure you talk to PM agent so they won't charge you the $5
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
3 weeks ago
My Samsung Galaxy S25 is compatible. This must be a mistake by Public Mobile?
3 weeks ago
So I ran the check on PM's IMEI, and it say's "Phone Incompatible". So what does that mean? It means PM's database (whitelist) of phones is woefully out of date and incorrect. I know for sure (100%) my phone is 4G/Volte enabled. Now I don't think PM will actually charge me $5 bucks/Month surcharge. However, if they do then I'm gone. Would seem kinda silly to drop a $grand on a new Telus approved phone to save $2bucks a month
3 weeks ago
You think that's why PM didn't ok them (because of a risk to their network or liability to older phones)?
3 weeks ago
@waytay wrote:What a waste of perfectly still-good devices!
old devices might be working well, but they lack the security updates and easier to be compromised or hacked. Also, some apps, especially banking apps, might not even work with those "perfectly still -good devices" but with outdated OS
3 weeks ago
3 weeks ago
how long you used your S25? maybe PM still has your old phone on record
ask PM support agent to confirm if they see you having a S25 and let them know you shouldn't got charged with the extra $5
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
3 weeks ago
I got the same text message. I have a Samsung Galaxy S25. This makes no sense.
3 weeks ago
Apparently, until March 2027 when 3G ends. For most carriers/providers
3 weeks ago - last edited 3 weeks ago
You might have a 4G/5G phone, and a 4G/5G plan and using 4G/LTE/5G for data, and your phone might support VoLTE, But PM has a VoLTE whitelist and only phones on the list can use VoLTE.
3 weeks ago
Hello, I just received a message that I’m going to charge $5 more because of my device that uses 3G, I’m not sure why because I’m using 4G data on my phone & I don’t really understand the extra charge. I have no way of contacting anyone so I'm posting here.
3 weeks ago
Yeah the only issue with that is the message states "Your device uses our 3G network. Starting June 15, 2026, you will see a $5/mo 3G usage price increase on your bills if you continue using this device." If a user prevents their device from accessing the 3G network the CRTC might have an issue with Public Mobile charging people this "usage" fee if they aren't actually using it.
3 weeks ago
...or to move to Telus or Koodo (which accept many more voLTE capable phones)
3 weeks ago
@McMobile wrote:To enable VoLTE on a Xiaomi Max 2 dial *#*#86583#*#* in the phone app.
Then dial *#*#4636#*#* in the phone app, select the "phone"(SIM card slot where you SIM is located) , under "Set preferred network type" select "LTE only" this will prevent your phone from accessing the 3G network and should keep that $5/mo charge away.
hi @McMobile
this trick might work to get VoLTE working, but as long as it is not on PM's VoLTE whitelist, there is a chance still have to pay the $5
3 weeks ago
hi @Mauli
it is not the plan but the phone itself. Changing plan won't help. you likely need to change phone
yes, you might have a 4G or even 5G plan, and your phone might support VoLTE. But PM has a VoLTE whitelist and only phones on the list can use VoLTE. Your phone likely is not on the list, so while you are using 4G or LTE or 5G for data, when you are making calls, the system is now falling back to 3G for voice calls. So, when the 3G network ends, you won't be able to use any network for calls with your current phone
Then dial *#*#4636#*#* in the phone app, select the "phone" (SIM card slot where your SIM is located) , under "Set preferred network type" select "LTE only" this will prevent your phone from accessing the 3G network and should keep that $5/mo charge away.
3 weeks ago
on the Status bar it show VoLte.
Login to your account and go to Subscription tab-Manage Subscription-Change Subscription. There a list of plans you are qualified to speed to. The could be a plan that will be at the same price with more data.
3 weeks ago
Her phone is using the 3G system to make and receive phone calls. They are getting rid of 3G system March 2027. Some provinces already did since December 2025.
So they are telling her that she must buy a new phone that will be 4G at minimum to avoid $5 extra fee for now. Or come March 2027 she cannot continue to use that with Public Mobile.
So she needs a new phone that Public Mobile will support.
3 weeks ago
hi @Ihsain
take this screenshot and open a ticket with PM support agent to confirm
3 weeks ago
You need VoLTE to make or receive calls. Enter the IMEI of your Xiaomi phone to see if it is VoLTE compatible.
Here is more information:
If it is not compatible then you need to look for a new phone.
3 weeks ago
Thanks Sanson. I used P.M. whitelist for VOLTE checker and found my Oneplus is supported. Here is a screenshot of it. Any advice?
