10-04-2023 06:03 PM - last edited on 10-04-2023 07:51 PM by computergeek541
I'm trying to verify my LinkedIn profile and LinkedIn works with clearme.com for verifications. I'm getting an error that my mobile carrier is not supported and I went through a lengthy support process with the CLEAR team that eventually led to them recommending I contact my mobile phone carrier, as they couldn't do anything about it. Can you please advise on how I can remedy this?
The error message is as follows:
"We weren't able to verify your identity
Your personal information could not be confirmed.
This might happen if you're using an internet-based phone number or on a non-major mobile carrier.
Please contact CLEAR Support or use the CLEAR APP to update it to a number from a major carrier (like Bell, Rogers, Telus)."
2 weeks ago
I've been facing the same issue with CLEAR. This does not have anything to do with LinkedIn. LinkedIn relies on CLEAR to verify you. If you sign up with CLEAR directly, you get the same error:
I guess PM has no intention of resolving this with CLEAR
02-26-2024 03:16 PM
I have the same issue with a PM phone number and CLEAR verification for LinkedIn 😞
01-07-2024 07:38 PM
@hTideGnow , No No, my phone number was a mobile with kodoo in 2018. then I did the transfer to Public mobile in 2020 I think as I have 4$ promotional Loyalty.
And regarding this issue here is the chat text that CLEAR agent written to me :
I think you should contact your phone carrier to see if you're able to fully port your information to LinkedIn at all. Phone carriers under bigger companies such as Telus, AT&T, etc., it is recommended that LinkedIn users
connect with their carrier to identify when they’ll be fully ported to the new carrier network.
01-07-2024 07:31 PM
hi @mokamoka
and the phone number was never a landline number?
I don't know, we saw couple reports about LinkedIn, and other apps/website don't have this issue. not sure why LinkedIn has a different system
and they don't have a call back feature instead of text, right?
01-07-2024 07:28 PM
I'm with public Mobile for more than 3 years I guess Or maybe more. I ported it from Kodoo since more than 3 or years.
01-07-2024 07:26 PM
01-07-2024 07:24 PM
I have the same issue.
I contacted CLEAR, and they mentioned that the problem lies in LinkedIn being unable to verify our information from Public Mobile.
They suggested that the solution is to get in touch with Public Mobile and request the removal of all restrictions, allowing LinkedIn to access our information.
I don't believe it's feasible, as Public Mobile does not provide phone call and customer service support. Consequently, we are currently unable to take any action until assistance is available from other sources.
12-21-2023 05:01 PM
I have the same problem and CLEAR customer service told me that you must be a direct customer of Bell, Rogers or Telus to verify - they specifically do not accept any subsidiaries. Thus there is no resolution.
11-23-2023 06:49 PM
Same issue. I was told last month to try again in 30 days and talk to my phone provider (Sasktel). They had no clue what to do, but I am getting the same error message as well.
11-06-2023 05:58 PM
Having the same issue.
I think CLEAR has the database of phone number which is VoIP provider.
I cannot verify my profile with LinkedIn, and also cannot verify with DigitalOcean, all of them saying this is VoIP number.
I think PM should check if they can help customer in this case.
10-30-2023 04:17 PM
I'm having the same issue. I purchased my SIM and phone number directly from PM. Please let me know if anyone has any solutions.
It would be great if someone from PM team could reach out to CLEAR to fix this issue for everyone.
Thanks.
10-27-2023 07:32 PM
sent
10-27-2023 12:26 PM
@softech
I was previously with Rogers (a mobile line) and am still having the same issue. Can you please share the phone number to the porting team with me as well? I switched to Public Mobile a long time ago, so not sure why it's taking so long to transfer.
10-27-2023 08:05 AM
porting from landline usually takes 3 to 7 business days, it is normal
But I will still send you the phone number to porting team, call them and they will advise on the porting status
10-27-2023 07:55 AM
I am having the same problem. My phone number was ported from Bell (a mobile line).
10-04-2023 06:05 PM
it is not a PM problem but a problem with the system you are accessing , Linkedin
Did you port your phone number from a landline or VoIP provider? Those system like Linkedin has no way to check which provider you are with, all they do is the check the origin of your phone number (by area code and the next 3 digits), and if it was originally from a landline or VoIP , they would think it is a non-Mobile line. There is really nothing PM can do as it is not a PM issue.
