3 weeks ago
3 weeks ago - last edited 3 weeks ago
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
3 weeks ago
@SJA1 You can port your number out is one way , or in your account you can turn off auto subscribe
Turn auto subscribe off/on
If you can’t log into your account you can always ask support to remove the credit card on file right away
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
