Caribbean
Dc9r2757
hi gang, I work for a Canadian airline and am often in the Caribbean. Does public mobile work there and does anyone know of a plan that covers Canada, US Caribbean and Mexico? Thanks
8 REPLIES 8
DDM69
Airalo esim
Works very well and good pricing
DennyCrane
Telus offers plans that include the US and Mexico, but PM doesn't even have service behind the US. You could also consider Freedom Mobile.
But if you only need data (no phone or text), a travel esim from Airalo or Ubigi might make sense.
DDM69
Try the esim...Airalo.  Works reat.
hairbag1
@Dc9r2757
if you have wifi in those areas, you could just download free voip app such as TextNow. With it, you can send / rec free calls /texts to most Cdn or US numbers...fro free using the local wifi or separately purchased local data.
@Dc9r2757  Sorry PM only has roaming in the US . Your best to get local pre paid SIM card in Mexico for your visit
fixin
@Dc9r2757  - You cannot get roaming packages for international use, only the States is where Public Mobile has international roaming.
hairbag1
@Dc9r2757
Public Mobile will only work in Canada or US with a roaming add-on. For use anywhere else you should get a sim and a cheap local plan.
HI @Dc9r2757
sorry, PM only has roaming in US , not other countries.
So, best to use Travel esim as you likely fly a lot to many places
