Cant send messages - Telus Error 0
04-17-2024 07:16 PM
trying to send text messages but they wont go through, keep on getting Telus Error 0
I reset my network settings and this issue still persists
Service
04-17-2024 07:32 PM - edited 04-17-2024 07:32 PM
Public Mobile is dealing with issues when it comes to SMS on Android and iMessages and FaceTime and such. There is no ETA of when it will be resolved. I think it's starting to seep into other long term members too while they are trying to fix it. Here is their announcement.
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features, and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
- Public Mobile Team
Keep an eye on this thread as they SHOULD update it when things are fixed.
04-17-2024 07:19 PM
no, ive been using public mobile for a while now, so this isnt an activation issue
04-17-2024 07:17 PM
hi @Cav you just activated.? If so, it is a known issue, it is a PM system problem with new activation. Voice, data both work but just SMS is the problem. And with the SMS problem, it will affect account verification. PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
