09-02-2022
03:54 PM
09-02-2022
03:59 PM
computergeek541
I haven't been able to receive sms messages from Europe since July, even though my package has unlimited international texting. I had been receiving international texts for a few years before this and haven't had any issues. I'm not sure what the issue is.
I haven't changed anything recently (same number, same plan, same SIM), so I'm not sure what is causing this problem.
I read that Public Mobile changed their system a few months ago, could that be the cause of the issue?
09-09-2022 01:38 PM
09-09-2022 12:56 PM
Hi Esjiliv, I followed your instructions and I was able to have SMS from Europe for a couple of days, but now I am having the same issues (not being able to receive the SMS message). I have tried to reset it again as per your previous instructions, but I am not getting any results. I did try the sim card on another cell phone (different make) and I have come to realize that there are a lot of people with the same issue since July. Could the change be from Canada or from outside of Canada. Do you know any other solution. Could it be the package I have which is "unlimited international texting". Thank you for your great help.
09-02-2022 08:59 PM - edited 09-02-2022 09:02 PM
@Eurotec Are you expecting sms from European friends or system text like 2FA text from European banks? Most system generated text might not work , its some system limitations on the sender side instead of the receiving ends. So, most the time it's not an issue with PM
09-02-2022 08:44 PM
I am a longtime user.
09-02-2022 08:43 PM
Yes. I am a longtime user.
09-02-2022 08:41 PM
Yes. Yes. I am a longtime user.
09-02-2022 08:41 PM
Are all other texting in/out working okay @Eurotec ?
If so, there should be no reason why the europe ones are having issues.
If you cannot try your sim card into another phone...this would be a good test to see if this is a phone issus, the try doing a Reset Network Settings.
This operation will reset your Wi-Fi, mobile data network, and Bluetooth settings. It will not change any other settings on your phone or delete any data. Go to Settings > System & updates > Reset, touch Reset network settings, then follow the onscreen instructions to reset network settings.
If you did try your sim into another phone and still having the same issue (and you were able to receive these texts before) as CSA about this.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
09-02-2022 08:41 PM - edited 09-03-2022 12:20 AM
let tried this,
Delete the contact and Verify that their phone number is correct,
add it again.
09-02-2022 08:34 PM
@Eurotec - you started a thread already here: https://productioncommunity.publicmobile.ca/t5/Get-Support/Cant-recive-SMS-from-Europe/td-p/869761
I know you may have not received an answer yet, but it may help to keep the same issue all in one place. 🙂
09-02-2022 08:34 PM
Perhaps the sender in Europe has a restricted texting plan. Are you certain he is able to send to you in Canada ?
09-02-2022 08:33 PM
I have read somewhere that the mobile system has changed to 4G recently in July. I am an old customer and did not change my phone or settings. The phone is a Hauwei P20 Pro.
09-02-2022 08:32 PM
@Eurotec While you are in Canada you can receive texts from anywhere, from anyone that has the ability to text to you (with their plan).
Yes, July 13th had some updates to My Account, but that should not have affected your texting services.
Are you able to send to these Europe numbers without issue? What troubleshooting have you tried.
Have you restarted your phone recently, or tried your sim card into another phone to see if texts will go through then?
09-02-2022 08:29 PM
@Eurotec Are they sending it to you correctly with your long distance code in front of your number? Are they able to receive any texts from you?
09-02-2022 08:29 PM
Yes and I am an old customer and did not change my phone or settings. The phone is a Hauwei P20 Pro.
09-02-2022 08:28 PM
Did you Ever receive SMS from Europe?
Do they dial correct number with all necessary country/area codes?
09-02-2022 08:26 PM
Why can't I receive SMS lately. I am a longtime user.
09-02-2022 05:32 PM
you don't recive any SMS from Europe.. and you are in canada right?
what your device brand and model.
09-02-2022 04:04 PM
@Eurotec , where did you read about a system change that affected texting? The text service continues to allow sending and receiving text internationally when the phone is connected to the Public Mobile network.
