01-21-2022
03:15 PM
01-22-2022
10:15 AM
Dunkman
01-21-2022 08:39 PM - edited 01-21-2022 08:40 PM
@peterdudgeon28 wrote:See above
I want a call back
@peterdudgeon28 - if this is a Bell cell phone port, it should only take 2-3 hours to complete.
If this is a Bell landline transfer this normally takes 3+ days to complete.
Incoming calls are the last to port over.
Do not cancel the Bell services.
As for texting, if this was a cell phone port, this should work by this time.
EDIT - perform a reset of your device's Network Settings:
Is this a new phone to you? Or, was it working under another provider before?
Do you happen to have Chat Features turned on? Maybe turn this feature off and try SMS and MMS (with data on).
Disable your Chat Features:
01-21-2022 03:44 PM - edited 01-21-2022 03:51 PM
Edit:
Aha now that you have confirmed you cannot recieve calls then do call the telus porting department with your account number from Bell. Put the Bell sim back in your phone to reply YES to the PAT (porting authorization text) within 90 min of receiving it. Ignore below if after your port completes the rest of your services work normally.
If all of your other services are working then this is not a porting issue and the telus porting department can not help you. Can you post a screenshot of your APN? Is your OS up to date? Make sure their are no software updates available to you otherwise update your OS and reboot your phone before you check your APN to the one below. There are a couple of slightly different APN's that can work for public mobile.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
01-21-2022 03:35 PM
First check to see if your phone if the "Do Not Disturb" setting is turned on. If it is, disable the setting.
Second, reboot your phone by power off your phone then wait a few minutes then power on the phone.
Let us know if that works.
01-21-2022 03:32 PM
I can make a voice call, but not recieve one
01-21-2022 03:31 PM - edited 01-21-2022 03:32 PM
Please call the number that I sent you. And once you're done with the call, please come back here and tell us all what happened. All the best! 🙂
01-21-2022 03:30 PM - edited 01-21-2022 03:33 PM
@peterdudgeon28 ok, great you confirm about not able to receive calls, please call the number we sent you to confirm porting status
And, did you reply YES to the text from your preivous provider to approve the porting ? you did so within 90 minutes?
01-21-2022 03:30 PM
I can also make calls but not receive calls
01-21-2022 03:28 PM
Did you reply to the SMS text with YES confirming that you are switching from your previous carrier?
This is a very important step to complete your porting of your number. What is your issue? In most cases, we can help you with your issue if you can go into details of your problem.
Community members here are PM customers and are not PM staff. PM is an online service so no one will call you back.
You need to click on the SIMon Chat button or private message a CS_Agent.
01-21-2022 03:28 PM
This is likely to be a problem with the porting process not having been completed fully. I'll private message you a phone number to call for this. Watch out for you in your community inbox now!
01-21-2022 03:27 PM
@peterdudgeon28 wrote:When I try and send picture or text messages it looks as though they have gone like normal.
So, there is no error message you got? There are check mark showing it sent?
and can you confirm if your mobile data is working well?
01-21-2022 03:26 PM
Everything else on this phone is wotking normally
01-21-2022 03:26 PM
01-21-2022 03:25 PM
I just joined yesterday, my data is turned on
I set up a Public Mobile access point.
My phone is a brand new galaxy s9, i ported my number from Bell
01-21-2022 03:22 PM
HI @peterdudgeon28 ,
we might need more information from you.
How long you have joined PM?
is your voice calls working on both incoming and outgoing?
is your Mobile data working?
and just want to confirm, MMS requires Mobile data, did you check if your Mobile Data is enabled?
01-21-2022 03:18 PM - edited 01-21-2022 03:18 PM
PM does not offer any support over the phone (it is exclusively through this community forum). Also, this issue is most likely to be phone related and if it is so, PM agents will not be able to offer you any assistance with it.
(1) Can you share what phone you are using?
(2) What happens when you try to send a text message?
(3) Is this a new phone number? Or did you port it from a previous provider?
(4) How long have you been with PM now?
