10-14-2024 05:01 PM
I recently switched to the OnePlus fold and can't figure out how to send or receive photos or files from IPhone users
10-15-2024 07:20 AM
Make sure you have mobile data turned on. The rest is up to the iPhone users to make sure they have MMS enabled.
10-14-2024 05:44 PM - edited 10-14-2024 05:45 PM
Hello @Beenda
I'm an iPhone user myself and haven't touched an Android in over a decade so... fingers crossed my idea works. lol
Go and peek at your APN settings.
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
10-14-2024 05:09 PM
Reset the Network setting on your OnePlus phone and see if that works.
10-14-2024 05:08 PM
hi @Beenda but you can send pictures to Android users?
Sending pictures on Android is MMS. It works the same way when you send to Android and iPhine users. There is also RCS that works on both Android and iPhone but not all iPhines users have RCS enabled
and if you have trouble sending MMS, try Reset All Networks on your phone
