code for setting up phone number not being received
Levi199
Have a new Sim, chose number, send it was sending code, never received code to confirm phone, now need to confirm full access but code never comes through. Email code isn't an option they provide.  Phone number came with eversafe, I didn't not sign up eversafe
hi @Levi199
I assume you have not even got to the step about porting yet?  If you cannot login app, you cannot complete the activation yourself.  But let PM agent to help you.   You can submit  ticket by direct message:
Levi199
App was downloaded and that is were I was when I selected my phone number and it send it would send code that doesn't come through.  We requested new code numerous times.  I can't send out text or received texts so process is not completed.
Levi199
This is my first cell phone so no previous provider.
Dunkman
@Levi199
By chance, did you download the PM app to finish off the activation of account?  You can start registration on the PM website, but needs to finish off on the PM app.
slusagm
If you requested porting, the number could have sent to your old provider if the port not completed yet.
Or you can ask PM to check
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
