10-09-2021 10:48 AM - edited 01-06-2022 03:31 AM
Good day everyone
I have this issue where I just changed my phone from an iPhone to a Pixel. Before, everything worked fine, but now, since I got the new phone, I'm unable to reach my voicemail. When I dial the number (and I've try several number several times) it just say call ended right away. I use a Pixel 4XL with graphenOS (Android 11). Does anybody had any issues like this? Thanks
10-11-2021 06:26 PM
@Caltor whichever way fixed your issue, important thing is you have no problem with your VM now. thanks for coming back for your feedback.
10-11-2021 06:18 PM
@Caltor wrote:Since I did both, I don't know what fixed it though.
EH! You should keep track after each intervention... That might help somebody else in the future...
10-11-2021 05:49 PM
I did both tips (cleared cache and network reset) and it worked. I can now call my voicemail from the mobile. Since I did both, I don't know what fixed it though. Anyhow, thanks a lot for the support. 🙂
10-09-2021 04:13 PM
@Caltor wrote:Good day everyone
@Caltor - try below:
Press and hold the power button on your Pixel for 10-15 seconds. Choose restart.
Clear Cache
Have you tried the Reset of the device's Network Settings as @Dunkman mentioned?
10-09-2021 12:49 PM
10-09-2021 12:48 PM
visit that link and go to name ( Nezgar )
Solved: Unable to Get Voicemail working - Page 2 - Community (publicmobile.ca)
Check your voicemail messages from another device,
10-09-2021 12:40 PM
@Caltor try to post your question at Reddit/GrapheneOS, there are more Graphene users and experts there, they might be able to help
10-09-2021 12:34 PM
Thank you everyone for the answers, Unfortunately, none of that works. I managed to access my voicemail from an other device though. I believe it has to do with the OS i'm using. It an OS that push for more security so it is possible it blocks the access to voicemail.
10-09-2021 12:21 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and make call to your number from your device,
10-09-2021 11:57 AM
@Caltor if you go into your Phone App, click 3 dots, Voice-mail, then voice-mail settings, do you see voicemail number settings that you can actually change number? if so, you can update the voice-mail number. choose any PM VM number from the link in previous post.
10-09-2021 11:24 AM
On Android I never dial a specific number for voicemail. I just go to the phone app -> voicemail -> call voicemail. Give that a try if you haven't already.
10-09-2021 11:15 AM
@Caltor wrote:Thanks for the reply. However, the holding 1 button or calling my own number using my phone does the same (call ended right away). As for using a land line or another phone, I'll try, but it won't solve the problem. I need to access voicemail from this mobile phone. I may not have access to other phone or landline.
It is likely a setup issue with your new phone. You new phone needs to call one of PM's voicemail access numbers. Try to reboots / network settings reset of phone.
Try calling one of these numbers from above link.
On Android, you might be able to check and change your voicemail access number in the phone app under Settings, Voicemail, Setup, and edit the voicemail number from there.
10-09-2021 11:07 AM
10-09-2021 10:53 AM - edited 10-09-2021 11:10 AM
To access voicemail messages from your mobile device, hold down the ‘1’ key on your phone keypad. You can also access your voicemail from a landline or any other phone line, by dialing your 10-digit phone number, selecting ‘Send’ or ‘Call’ and then pressing ‘*’ to skip the system greeting.
Try rebooting your phone. If you have another phone then try swapping the sim.
