Cannot login...
Teezem
I have cleared my caches restarted my phone, my browser and have tried using different browsers and in incognito mode and still I receive the "Page Expired" page. This needs to be fixed.
15 REPLIES 15
statusquo
Thank you teezem and softech  and yes learn something new everyday!  I also use chrome but so far I haven't had this come up but will remember for the future.
I
Teezem
Chrome, Edge and DuckDuckGo
Teezem
Edge has the feature.
@Teezem  which are the 3 browsers you use? Chrome is one of them I guess
Teezem
It was with 3 different browsers and auto fill on but if I didn't click the Login button so fast I would have been fine.
@statusquo   I know Chrome for sure has this feature
I think Edge has it, too (not 100% sure)
Not sure about Safari or other browsers
statusquo
Is this a particular browser problem or do all browsers have this though I don't remember encountering it before but it's nice to learn about these things.
Teezem
Ya, you're right, if you're too fast with the Login button you won't notice. Hehe
Learn something new everyday!
Teezem
@softech has the solution.
@Teezem  actually it is a browser feature, but not very good in our case... LoL
Teezem
I was clicking the Login button, not clicking and waiting IS the trick!
I didn't look close enough to notice that it was processing the login without clicking that button.
@Teezem
you are using saved password?
Page Expired because you are using saved password and you click Login button
yes, just not click the Login button.  Once you pikced your saved password, do nothing, the browser will automatically log you in and you should be all good
@Teezem @Did you clear web browser history
statusquo
I agree with you public mobile should be fixing this but now you will need to wait and try later if you cannot get in.
Meow
Try to use Computer, not phone
