Login issue
Zebra91
Trying to log into my account, to manage subscription, but I am being asked to verify SMS OTP without the option of switching to email OTP due to not having service with sim
2 REPLIES 2
March_Can123
To get past the SMS two-factor authentication (2FA) screen when they don't have SIM service, they should click "Didn't receive code" or "Resend code" on the verification screen to switch to email, or contact a Customer Support Agent if the email option does not appear.
1. Force the Email Verification Option
  • Look for the secondary link: On the screen asking for the 6-digit SMS code, look closely underneath the input box for a link that says "Didn't receive code?" or "Resend code".
  • Select Email: Clicking that link usually reveals an option to send the One-Time Passcode (OTP) to your registered email address (or via voice call) instead of SMS.
  • Try a different browser: If the option is missing or grayed out on the Public Mobile app, log in via a desktop or mobile web browser in Incognito/Private mode at myaccount.publicmobile.ca.
2. Why Email Might Be Missing & How to Fix It
  • Account setup or old SIM: If your EverSafe ID was only ever configured with SMS 2FA—or if your account is suspended for more than 90 days—the self-serve email fallback may not show up.
  • Contact CS_Agent directly: Since you cannot log into My Account to submit a ticket normally, you should send a private message to CS_Agent directly through the Public Mobile Community Private Message Portal (the Community login often works even when My Account blocks access, or you can create a free Community account to message support).
  • Ask for a 2FA reset / email update: In the message to CS_Agent, you  should ask the agent to send the verification code to your email or temporarily update their EverSafe 2FA method so you can access your subscription.
@Zebra91
You will have to engage PM Customer Support and they can change the settings for an email 2FA.
Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account.  Select Start a Chat to begin:
          https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
** If you cannot receive 2FA code via SMS and unable to open ticket, please setup a new Community account using another email and DO NOT link a phone number to it.  You can then create an Expert Messaging ticket with this new account.
