Cannot call voice mail
roushenas
Hi all,
I changed my plan for the new period of time, and I received a voicemail message from a call that I missed. But the problem is, every time I try to connect to the voicemail, it shows an error page:
What is wrong with my account and how can I call my voicemail? Establishing a connection is not possible at all.
Best regards
CAL21
Thank you for this.  I had the same problem.  Calling my own number was the quick fix and rebooting brought everything back to normal with the automatic voice mail calling from the voice mail icon.
Priority
Instead of calling voicemail directly have you tried dialing your own Phone Number? That also calls Voicemail.
DennyCrane
How are you calling into your voicemail? There's no visual voicemail on PM. Long press 1 on your dial pad.
Chalupa_Batman
Dumb question. Have you tried rebooting the phone?
Also, go into settings, network settings, uncheck Automatic and pick Public Mobile. Then reboot the phone. Let us know if it worked.
