08-06-2023 09:53 AM - edited 08-06-2023 03:49 PM
Found the problem by taking advice from responders. Deleted the +1 in front of the number and it works fine 🙏
08-06-2023 03:51 PM
Took the +1 away in front of the actual number. A friend had the same problem texting her sister who live out of town.
08-06-2023 03:49 PM
@Catloverx2 glad it works
what did you do in the end?
08-06-2023 03:45 PM
Got it working. Thanks everyone for the advice 🙏👍.
08-06-2023 10:54 AM
hi @dust2dust
hope Op read the message and will test. So far, no message from OP
08-06-2023 10:44 AM
lol Great idea @hTideGnow . I just tested to one of mine and it went through fine just to see if there was some kind of system problem.
08-06-2023 10:38 AM
hi @Catloverx2
I will send you my US number by private message. send a test sms there if you want
08-06-2023 10:25 AM
What we're basically saying is that you certainly should be able to text to the states (and everywhere else). So read the replies carefully and try to test or answer all the questions so we can help narrow down where the problem might be.
08-06-2023 10:22 AM
@Catloverx2 you can try to setup VoIP app with US phone number to confirm
Also, check usage history and see if the text you sent is there
you can also download Google Message, set it as the default and test again
08-06-2023 10:16 AM
I can't text another US number. My Phone is a Moto 5 Pure, not sure what he has.
08-06-2023 10:12 AM
@Catloverx2 anyway you can try to text another US number?
you can setup the test yourself. Download The VoIP app TextNow, pick a US phone number and test sms there
and any chance you are on iPhone and your friend on Android ?
08-06-2023 10:07 AM
Does it seem to be going through as far as you know? Is it only just the one number? Maybe he blocked your number. Can he give you another number to test like from a friend or relative of his? Can you share the first 6 digits of his phone number? There are some places you can't call but I'm not sure if you can't text those restricted numbers.
Can you real sms text people in Canada?
iphone or Android? If Android then maybe you could clear the app cache of the texting app you're using. Or edit his contact using a one digit off number and then manually type his number and try to text to it. Is the friend in the US and using a US provider? Or physically here and not roaming?
08-06-2023 10:00 AM
there is
08-06-2023 09:59 AM
yes, there is a+1 in front
08-06-2023 09:56 AM
@Catloverx2 did you put a 1 on front of the 10 digits?
