a week ago
My son ordered twice by accident. We cannot access the first phone number he received therefore we are unable to go in and cancel it. He did it again and now has a working number to his phone but I really need the first account canceled!
a week ago
@Rickii , by chance did your son use the same email address in creating the second account? That would explain access problems to the first account. A relative went through the same issue recently and I had to step in to assist. The simplest way forward was to have to charges incurred for the first account credited to the second account. Make sure to have support remove the credit card on the first account just in case to prevent any future errant charges.
a week ago
HI@Rickii
support should be able to help. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
a week ago
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
