Canada-US subscription
JohnnyRocket
I have a Canada-US subscription. It did not come with instructions. What do I do to get coverage by US carriers when I cross the US border?
hairbag1
@JohnnyRocket
the others have discussed talk and data but for texting, it should just work without changing anything. Make sure roaming data is turned on for data while in US.
@JohnnyRocket  Ensure data roaming is on in phone settings . And set phone to 4G/LTE and connect to T mobile or AT&T . If still voice not working try phone set to 2G and connect to T mobile only
@JohnnyRocket
when you are in US, make sure you try to connect to T-Mobile and AT&T network. If it does not connect automatically, then change the Network connection to manual and select try  T-Mobile and AT&T manually.
For data, make sure you enable Roaming Mobile Data on your phone.  Change network mode to 4G/LTE  (do not use 5G)
If your roaming purchase includes voice, enable VoLTE on your device and you might be able to use VoLTE for voice.  But if not, your phone should change to 2G network on T-Mobile ONLY and test voice calls
HI @JohnnyRocket
all you need to do is make sure mobile data roaming is turned on
try to connect to T-Mobile or AT&T, if it doe not automatically connect, try manually
test voice.  Most the time VoLTE would work, but if not, use T-Mobile and change network to 2G
