Canada-US Subscription Plan Question
MattyV
The Canada-US subscrption - does that use our data we currently have in our plan when we go to the US or do we need to buy a add-on to have data in the US? Just want to confirm as it just mentions, calls, texts, and etc.
@Sunstorm, yes you are correct. The PM SIM will allow you to connect to their approved U.S. partners T-Mobile and AT&T. Some customers have reported that Verizon has worked for them as well but not all customers. If you have your phone's cellular settings set to Automatic it should connect to the strongest signal but if it's working well for you change your settings so that it's no longer on Automatic and manually select the carrier you want to try connecting to. Be sure to leave Date Roaming ON
Sunstorm
If I understand correctly the Public Mobile SIM can connect to either T-Mobile or AT&T ? The phone will just connect to the strongest signal or? Maybe you have to manually connect?
MattyV
@eddieO Thanks Eddie!
eddieO
@MattyV the only thing you need to be aware of its that you need to have your Data Roaming on and just keep an eye to see which US partner network you are connecting to, should be either T-Mobile or AT&T. If one is not working well try the other
MattyV
@Handy1 Thank you for confirming!
@MattyV  The CAN/US plans are true snow bird plans and can be used in both country to call to and from and use talk text and data in either country . No add on needed  roaming is built into the plan itself
