01-09-2022 05:47 PM
01-10-2022 01:05 AM
@ryan5oh: I don't know how far you've got with this but...
https://support.apple.com/en-us/HT209044 and scroll down a ways to :
Change your cellular data number
That sounds a lot like what I was mentioning with my Android phone.
01-10-2022 12:25 AM
Lol...I had a choice of deleting my bonehead explanation or leaving it to show I tested and realized I was completely wrong. I chose the latter rather than a blank post.
01-10-2022 12:21 AM - edited 01-10-2022 12:26 AM
@darlicious wrote:The basic reason for this is your phone switches to the 3G network for voice calls while you are set up for mobile data on the 4G LTE network. Ok forget this explanation I just tested it and mine works fine.
As you know, both HSPA and LTE are capable of both voice and data simulaneously. Any drop in internet connection should only be momentary and usually unnoticeable to the customer. It's possible that there are HSPA network capacity issues in ryan5oh's area.
01-10-2022 12:13 AM
01-09-2022 11:07 PM
@Anonymous wrote:go sign in to Self-Serve, to review your account,Data Usage.
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges...
Turning off background data would do the opposite of what the customer is asking for. I do understand if a customer has ran out of data, the mobile data would stop working, but data not working because of running out wouldn't in any way be isolated to when the customer is on a phone call.
01-09-2022 06:47 PM
That is interesting @Anonymous
I have a dual SIM phone, but have not had an opportunity to use this feature.
01-09-2022 06:44 PM
@ryan5oh : If the phone also has eSIM capability and maybe you're using it for another service then there might be settings to control that. My phone (Samsung A31 running A11) is dual-SIM and I use both and there's a setting called "Allow all SIMs to use data in calls". It goes on to describe the option "Let secondary SIMs use mobile data during calls. If this is turned off, you can't use mobile data during calls on secondary SIMs.".
01-09-2022 06:39 PM
@ryan5oh wrote:I've noticed that during a phone call, my data stops working. As soon as the phone call ends, data starts working again. Anyone else have this problem?
I have an iPhone SE (2nd gen. / 2020).
@ryan5oh - what is your Mobile Connection setting set at?
It is on a combined setting like this? Which I believe is normally recommended, unless you are in areas where you need to manually change to 3G temporarily for improved services.
01-09-2022 06:08 PM
PM does not offer VoLTE, which is what is discussed in the link my friend posted previously. I'm fairly certain this problem has to do with the way the network is configured. Perhaps a PM agent can shed more light on this for you. You can reach them by sending a private message on here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
01-09-2022 06:06 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
and try manually selecting network "3G ONLY"
for iPhone visit Here link
or Here link
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
01-09-2022 06:01 PM
01-09-2022 05:49 PM
