10-10-2022
09:32 PM
10-10-2022
09:35 PM
Dunkman
Hello,
I have used xxxxxxxx to reset password, and it said Success (see below). But when I go to My account using the new password, it didn't work.
Could you please help ASAP as i need my phone to access my work.
Regards,
Shenyi
Edit by Dunkman: removed personal information
My Account
10-11-2022 12:34 AM - edited 10-11-2022 12:42 AM
Just FYI, I have got the same experience trying to log in tonight. also subbed a ticket.
EDIT: verification code never sent by email, had to use phone number.
10-10-2022 11:32 PM
thank you. submitted a ticket. 😀
10-10-2022 11:21 PM
@Shenyi wrote:Thank you. I have tried all those suggestions but I still get the same error message.
@Shenyi so, you tried Incognito mode or a different browser and then use the latest password you set to login?
If that is the case, you will have to open ticket with PM support. Since you cannot login to My Account , this is how you would hope ticket for this situation:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-10-2022 11:10 PM
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
10-10-2022 10:34 PM
10-10-2022 10:21 PM
you might have picked the wrong solution!! take advice from last post
10-10-2022 10:19 PM
@Shenyi wrote:Thank you. I also exceeded max login attempts. Do I have to wait three hours to retry?
There is no wait time. The lockout is for that browsing session. Clear your cookieds and close the broweser. Open the browser and try again.
10-10-2022 10:17 PM
@Shenyi you don't. The 3 hours limit is no longer there
Did you try using Incognito mode? or you try to use another browser? Try that with the new password you have just reset.
10-10-2022 10:01 PM
10-10-2022 09:35 PM
Try a different browser or device or use private mode. The site can be flaky.
10-10-2022 09:35 PM
The self service account is finicky.
Try to login in using a different webbrowser, clear cache or incognito mode. Or try a different device.
P.S. I will remove some of your personal information from this public forum
