Can't send pictures through text message
Alveeto
Hi,
I can't send pictures to two of my contacts through text message.
I have an android phone and noticed this problem about a month ago.
Please rectify.
CptPlanet
Hello, I also have a OnePlus 8 Pro and have not gotten MMS pictures to work. The bellow APN settings did not work.
Did you manage to fix yours?
Shubh2023
Hey, did it work for you? Let us know!
Alveeto
Manually changing the settings for it to work. Thanks.
Alveeto
One Plus 8 Pro. I'll try the reset.
@Alveeto what phone do you have? maybe it is affected by this
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
