SAMSUNG Galaxy A15 5G compatibility
Kev12
Good Day All,
I'm thinking of picking up this phone on Amazon:
SAMSUNG Galaxy A15 5G Dual SIM (128GB, 2024) 6.5" 90Hz AMOLED, 50MP Camera, 4G Volte (Fully Unlocked International Model)
It says International Model, will it work with Public Mobile in Canada?
Thanks,
Kev
Kev12
Thanks for the replies.  Ok, so I think I'll just go with this CAD model then:
Samsung Galaxy A15 5G 128GB Android Cell Phone (Unlocked CAD Version and Warranty)
HI @Kev12
yes, it is a great phone and will work on PM.  But only thing is not all phone can use VoLTE on PM and this is not one of them.  But no need to panic, you can still use 3G for voice calls.  Many of us are using 3G for voice and nothing wrong with that
So, you can buy this phone and use it here without problem
fixin
@Kev12 - It is compatible for the LTE network on PM for data but only 3G calls can be made.
