01-01-2025 01:15 PM
My messages are not being delivered and I am not receiving any messages.andMy plan is 5G Canada and America Wide, but my phone is an iPhone 13 and it shows 3G
01-01-2025 02:14 PM
@Mahmoud4 couldnt make ticket . (HTML error)
Either delete anything in the message that is copied and pasted from somewhere else, or copy the message to a notes app, remove the text from the private message, and then paste it back from the notes app. It's a fairly common glitch in the system.
I don't know why your phone is only on 3G then, ask customer support when you manage to get a message through to them.
01-01-2025 02:13 PM
01-01-2025 02:10 PM
Its already on Auto 5G
01-01-2025 01:54 PM
It is on auto 5G
01-01-2025 01:53 PM
@Mahmoud4 For the 3G issue, go to Settings - Cellular - Cellular Data Options - Voice & Data and if your phone is set to 3G there set it to either 5G Auto or LTE, whichever you prefer.
01-01-2025 01:50 PM
01-01-2025 01:49 PM
I did but still not sending and recieving any text
01-01-2025 01:43 PM
I did
01-01-2025 01:39 PM
Yes phone call and data is working. iods is 18.2. several times i was reset my phone but still not deliver and send any message
01-01-2025 01:37 PM
hi @Mahmoud4
you will need support to confirm. , you can submit ticket by direct message:
01-01-2025 01:33 PM
Hi.Call and data works well , My phone has been updated and I even put my SIM card in an Android phone and it still didn't work.
01-01-2025 01:27 PM
hi @Mahmoud4
phone calls and data work?
make sure iOS and carrier profile are both updated
then reboot the phone first, and Reset network settings and test again
