01-05-2024
09:39 AM
01-05-2024
10:54 AM
Dunkman
01-05-2024 09:50 AM
If possible, put your phone to 4G/LTE and connect to T-Mobile or AT&T.
If calls still don't work, put your phone to 2G and connect to T-Mobile. From the settings menu, turn on data roaming.
I hope this will be helpful.
*** you sent a message already. Why are you sending again? Are you reading the reply how to action?***
01-05-2024 09:50 AM - edited 01-05-2024 09:51 AM
@Wally4community answered you here in your first thread
But here goes again
Do you have a US roaming plan or add on ? You need to to use phone in the US . If you do make sure the phone is set to 4G/LTE and connect to T mobile or AT&T . If you still have issues with voice set phone to 2G and connect to only T mobile also ensure you have data roaming turned on in phone settings also
01-05-2024 09:49 AM
I have a canada us account .in the us and can’t receive calls or send any
01-05-2024 09:42 AM - edited 01-05-2024 09:46 AM
@Wally4 Do you have a US roaming plan or add on ? You need to to use phone in the US . If you do make sure the phone is set to 4G/LTE and connect to T mobile or AT&T . If you still have issues with voice set phone to 2G and connect to only T mobile also ensure you have data roaming turned on in phone settings also
