Reissue number transfer with previous provider
Anakin
Hello,
I need help reissuing a number transfer request to Telus. When I initially switched providers, Telus sent me a message to authorize the number transfer but I could never deliver my confirmation due to poor cell service.
I called Telus as I believe it was an issue on their side and they told me that the new provider public mobile now needs to reissue a new request for the number transfer and try approving again.
how can I have public mobile reissue a number transfer request to Telus?
thanks
2 REPLIES 2
hi @Anakin
check with PM porting support team and confirm the status or update the info if needed.   I will send you the number to PM Porting support team  Please check your community inbox
@Anakin  No worries I’ll send you the porting team number private message . They can re start the port request for you
check your inbox for the number . Or use this link to the community inbox for number
