2 weeks ago
I have done everything that I was asked to do to transfer number from old provider but they have not sent me a code I have been waiting 15 hours. I must be doing something wrong I need help
2 weeks ago
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
2 weeks ago
@Cabogal wrote:I have done everything that I was asked to do to transfer number from old provider but they have not sent me a code I have been waiting 15 hours. I must be doing something wrong I need help
Hey @Cabogal
Sounds like your porting request didn’t work.
There are two options. There is a number you can call that is primarily used for Koodo and Telus but some have had success using it with Public Mobile porting issues. Please go to your inbox using this link to see the number as they don’t allow the number to be posted on the forums. Since @Sansan already sent it to you, I won't send you a redundant message. Check this link for his message.
Alternatively, and according to Public Mobile CS Agents, since Public Mobile is a self serve service, they prefer you create a ticket. Here is a direct link on how to contact a CS Agent.
2 weeks ago - last edited 2 weeks ago
Did you provide your correct account number? Is your account current?
Anyway, I will send you another message with a phone number to call to discuss Jr with the porting team
