4 hours ago
Hello,
I did a number transfer from Fido, everything was successful. I can call out from my phone with no issues, but nobody can call me from a land line, they get "number not in service". Interesting thing is that friends with Rogers cell phones can call me and it works. So did the transfer did not work 100%
Thank you for any help,
Vanessa
3 hours ago
Thank you for all the suggestions. I'll check the settings again. I may have renamed the label to "Public Mobile" eSIM when I deleted the Fido eSIM.
3 hours ago - last edited 3 hours ago
Did you reply with YES to the text from Fido confirming you are porting over to PM within the 90 minute window?
4 hours ago
Did you remove the Fido sim card or disable Fido eSIM?
make sure PM sim is the only one enabled and set with Label Primary. Then proceed with Reset network settings on the phone after a device reboot
if issues persists, ask PM agent to check and confirm if the port was completed.
