06-26-2026 06:05 PM
My number port from Freedom Mobile is stuck. I no longer have calling or texting. My eSIM activation failed with ‘ eSIM could not be activated.’ and I could not reply YES to the Freedom authorization text because it showed ‘Not Delivered’. Please check the port status and reissue or reactivate my eSIM if needed.
I have tried three times to submit a ticket on this and each time even though everything was completed on the ticket it either gave a 404 error or would not send. I am completing this on WIFI.
06-26-2026 06:31 PM
Thank you. I am new to this.
06-26-2026 06:11 PM
hi @Smileygrey ask PM to help. if you cannot submit ticket with Chatbot, you can submit ticket by direct message instead: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
