02-14-2024 01:58 PM
02-14-2024 02:02 PM
HI @Sylvidor
is that a new account? and you requested porting?
If it is , call the porting support team and they can check if porting was done. I am sending the number to your community inbox. Check and call them
02-14-2024 02:00 PM
has it ever worked or is this a new acct ?
02-14-2024 02:00 PM
A little more info would be great!
Is this sudden?
Did it work before?
Can you receive calls.
Did you port over?
Try rebooting phone
02-14-2024 02:00 PM
@Sylvidor Did you just port a number into PM ? Did you leave the old providers SIM card in the phone to reply YES to the confirmation text ? Or miss the text ? If so I’ll send you the porting team number private message and they can re trigger the port request for you
