01-25-2021 11:00 AM - edited 01-05-2022 05:00 PM
Just the other day my phone stopped opening MMS texts. I have lots of data and to my knowledge nothing has changed on my phone. I have a Samsung A11. Not sure I put this in the right place.
01-25-2021 11:37 AM
Thanks, somehow my mobile data got turned off, turned it back on and pics are back. Thanks all!!
01-25-2021 11:31 AM
Rebooted phone, turned wifi right off, data is on because up till about 3 days ago I was able to receive pics and they opened no problem.
01-25-2021 11:16 AM
If you are using Android then try the following.
https://www.tenorshare.com/fix-android/why-is-my-mms-not-working-on-android.html
01-25-2021 11:03 AM - edited 01-25-2021 11:04 AM
did you try reboot your phone?
just MMS not working? incoming/outgoing calls and SMS are working?
Also, make sure data is turned on.. (no airplane mode or so). Data has to be on for MMS to come through (just wifi is not enough )
