Can't make outbound calls to landlines
NinaM
Hi there!
I can't seem to make outbound calls to anything but other TELUS numbers. I can't reach any landline numbers in the 705 area code and still trying to test other area codes with Bell landlines.
Help!
@NinaM
Outage map in your area:
https://istheservicedowncanada.com/
NinaM
Hey there!
I'm not new to PM, nor is the phone/sim new. Everything's been working great until just recently. If I had to guess, there's probably an issue with the interconnect of the TELUS mobile network and Bell/Northern Telephone.
@NinaM  Try resetting network settings see if that helps also is it possible to try the SIM card in another phone to test . If still no luck please use this direct link to support to help
send a  private message   To CS_Agents click
Chalupa_Batman
Is this recent? Are you new to PM? Did you just port in from another service?
