01-04-2023
03:05 PM
01-04-2023
05:09 PM
computergeek541
I am in the US visiting family I put the package on my phone for data and unlimited text and talk but I can’t make a call out and no one can call me
01-05-2023 07:02 AM
Where are you in the US? You probably do not have 2G network signal to connect to but you may have one near to you that may be blocked by other structures, topography, trees etc...
More info about US Roaming here....
01-04-2023 04:48 PM
Keep in mind, that US add-ons (at least until very recently) expired exactly 240 hours after purchase.
Can you screenshot the one your purchased, and include the purchase date?
01-04-2023 03:10 PM
According to Public Mobile:
PM will have T-mobile 2G network for US roaming. Try to manually connect to T-mobile and have roaming on.
Voice and SMS text will still work.
Data will work on LTE, but will switch over to 2G to make a call.
However, the quality of service will vary depending on the different coverage areas when roaming in the USA.
01-04-2023 03:07 PM
@Heather0292 just want to confirm , did you get the Roaming Add-on? when did you get it?
if you got the roaming addon within 10 days ago, try to connect to T-Mobile first and see if it works.
if it connects, check if Data works as data is the easier one to get it working. just make sure you hve your Roaming Mobile Data enabled on your device
if data working, then you can try text and then try tallk
let us know how it goes
