03-05-2025 08:43 PM
My Public Mobile Account has issue, so I purchased a new sim card and active it, But still can't make phones calls(I can receive messages and use data without issue all the time), But another Publice Mobile SIm card can be used on the phone without issue( I insert both sim card inside and approvl that). You can see the first SIM card with HD sign will work, without HD will not work, I worked with Agent for couple of days already without lucky , Any one please help, I don't want to switch phoen with others.
03-05-2025 11:30 PM
I tried to insert my SIM card having issue to my iphone and it works but weired way:
When I make phone calls, I will see it changes or swtich to 3G, While I use date, it will change to 5G+.
So that is some setting from Public mobile need to enable something or HD when I make phone calls.
03-05-2025 09:09 PM
The SIM card will work on another iPhone just has issue on the phone and the only different is HD beside SIM card one and no hd sign beside SIM card 2
03-05-2025 09:05 PM
Since Mom’s SIM works in your phone and the Grandpa M’s SIM doesn’t work. It sounds like it is related to the Grandpa M’a account.
Call 1-855-4PUBLIC from another phone since 611 doesn’t work to check on the status of the account.
Check to if the account is suspended with an expired CC on record. If it suspended, you need to make manual payment to continue service.
03-05-2025 08:57 PM
And I already worked with CS agent for almost one week, no lucky
03-05-2025 08:54 PM
As my screen shot , I insert two Public mobile SIM card into my phone, one is working , one is not.
03-05-2025 08:47 PM
this usually wont be a sim card problem.
There have been some service issue and it could be just that
Also, what phone do you have. PM is doing something with the 3G network and some phones from Asia might not work, that could be the reason instead of the sim card
or you can ask PM support agent to confirm ,
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
03-05-2025 08:45 PM
I can't make phone calls or receive phone calls.
