01-05-2023
08:24 AM
01-05-2023
05:48 PM
computergeek541
01-05-2023 09:07 AM - edited 01-05-2023 10:33 AM
@candacesask are you sure those are not incoming calls or incoming text?
do you mind to provide screenshots of some of those unknown number usage?
and there are explanation for at least three numbers:
474663
you are using iPhone? It is a a text for iMessage and facetime to enable on the current phone
212121
it is a text message for Forever21. you remember getting text from them?
1-877-779-1575
this is TekSavvy. You use their internet service?
or they called you for marketing?
01-05-2023 08:40 AM
Nope , there’s actually a lot of numbers, like 1-999-999-999 , 212121, 13069934000, 474663, 15193061575, 6689 , 18777791575… just to name a few
01-05-2023 08:29 AM - edited 01-05-2023 08:31 AM
@candacesask wrote:
- So going through my data usage, for calls and texts, and there’s numbers on there I don’t know, out going calls I’ve never made…. Ummm when I need a code that’s been sent to my phone, I never get it, my calls are ALWAYS being dropped, I don’t know what to do about this situation…. Help!
@candacesask - does the number you do not recognize end in 4001? That would be your voicemail phone number. Any time someone calls it or you check your voicemail it would show up in your detail history.
As for not receiving short codes and calls being dropped that is another issue, I think.
Can you try your SIM card into another compatible phone to see if the issue persists?
Some trouble shooting to try for network/SIM issues:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
EDIT, is this for a newer activation account/number, OR an existing one that this happened all of a sudden?
If there are other phone numbers that you are sure are not being made or received in your detailed history, OR, you continue with service issues, you may want to inquire with a CSA about it.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
