01-05-2023
08:22 AM
01-05-2023
05:50 PM
computergeek541
01-05-2023 09:13 AM
@jtrohak did you check using Incognito mode and confirm if your account is currently ACTIVE? Yes, you have add fund to it, wonder if PM system took the money and apply for renewal.
Please check again Using Incognito mode and also confirm it on Payment page, it will show how PM used the fund
01-05-2023 08:34 AM
@jtrohak - what does the status of your account say..ACTIVE or Suspended?
If you have no services and your account is Suspended, and it is past your renewal, maybe your autopay failed?
Add Funds, manually (which is sounds like you did!), to your owing amount or more, through My Account (or by calling 611 if you have a card registered), then select to reactivate/resume services if it does not automatically do so.
If your plan still does not reactivate / resume and it shows $0 owing, try adding a $1 top-up payment.
Or try
If this was an Autopay failure, I would let the Customer Support Agents (CSA) know.
If you have no services and your account is ACTIVE, try:
01-05-2023 08:30 AM
@jtrohak @You might wanna reach out to support assistance in this case
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
